S32K1xx FTM module
S32K1xx FTM module
1,824件の閲覧回数
chuanlin
Hello, may I ask if the CHF bit will still be set to 1 when the FTM module triggers an interrupt event in VLPS mode .
3 返答(返信)
1,807件の閲覧回数
danielmartynek
Hi @chuanlin,
The FTM is not a wakeup source.
RM, Table 7-8. AWIC stop and VLPS wake-up sources
The module is not functional in VLPS.
RM, Table 39-4. Module operation in available power modes
BR, Daniel
1,786件の閲覧回数
chuanlin
Hello, during testing, it was found that the FTM module can still be set to CHF after about 20ms of sleep for the first time. Is this a chip feature?
1,776件の閲覧回数
danielmartynek
Hi @chuanlin,
FTM is not supported in VLPS and should be disabled before the MCU enters VLPS, we can't guarantee FTM functionality in VLPS.
