S32K324 SWT RESET
S32K324 SWT RESET
1,244 次查看
Jon123
S32K324 a core running watchdog, when the watchdog time-out reset, want to reset only one core, how to set, the current test results are two cores reset together. These two cores do not turn on lockstep mode.
1 回复
1,206 次查看
petervlna
This is not possible. As there is only 1 RGM module, it will always reset all cores.
Peter
