S32K148 LPO Clock source for Watchdog, RTC. Is it reliable for long term running
2,679件の閲覧回数
kasirajan_chellaiah
My product have sleep mode option.  Can I use LPO Clock source for long term running in my product .I try to use these clock source in watchdog, RTC.  Is it very Reliable ?   If not , May I know the solution to the clock source for sleep mode ?
2,666件の閲覧回数
danielmartynek
Hi @kasirajan_chellaiah,
The LPO clock is not very precise:
The LPO can be trimmed (41.7.1.5 Low Power Oscillator Trim Register (LPOTRIM)).
However, one step of LPOTRIM[4:0] gives about 3kHz difference in the LPO frequency.
So, the RTC won't be precise.
If you need the RTC to be precise, you would need to use RTC_CLKIN.
2,667件の閲覧回数
danielmartynek
