S32K148 Input capture constant reset
1462993357
  • PWM output:PTE20 FTM4_0
    Input capture:PTD13 FTM2_4
  • Connect two pins with dupont wire.
Test input capture with component [ftm_ic],The debug software keeps resetting. what is the reason.
It is normal to disconnect the DuPont line.
(view in My Videos)
Robin_Shen
Hi  ruide,
Have you refer the ftm_signal_measurement_s32k148 example?
Robin
