S32K146 RTC
S32K146 RTC
Artemis
I want to test the difference between the MCU internal clock and the real clock, and I want to use the RTC module to record the time, but I do not know whether it is my configuration problem or other reasons, the RTC clock is nearly 5 minutes slower than the real time every hour. The LPO clock I use, Can you tell me how to configure the RTC module if I want to accurately time.Thanks
Senlent
Artemis
When I followed the tutorial to configure when I encountered a problem, when set to 32kHz crystal, the time count is very fast, the external one second, the internal clock ran more than ten minutes, I would like to ask why this problem. thank you.
Senlent
Hi@Artemis
It may be that your RTC-related clock is not configured correctly. Please refer to the routines in the IDE or the demo in the link. This is not a very complicated problem.
Artemis
Thank you.The accuracy has improved a lot after using LPO compensation, but still, I am considering using external crystal oscillator to achieve accurate timing
