S32K146 CAN callback function will only enter once
547416104
Hello EveryOne,
Init can_pal module and test can function, I find can tx function is ok, but CAN callback function will only enter once, if continue send can message from tester, system will not enter callback function.
The detail information refer to the attachment.
thanks!
PetrS
after callback is called you need to call CAN_Receive to start receiving data in given RX MB again.
Can be done in callback, i think, after you process data.
BR, Petr
