S32K144 WDOG
S32K144 WDOG
1,159件の閲覧回数
dzkk
Hello community!
     IN the FS32K144HFT0VLLT project, I found that the MCU would occasionally reset and then I found the value of the RCM->SRS register is 0x20 when reset happened.It means WDOG out of TIME.How can I quickly locate the cause example somewhere crash?
  Any help would be greatly appreciated. Thank you!
1,136件の閲覧回数
VaneB
Hi @dzkk
The Watchdog timer is enabled by default be sure to refresh it or disable it.
If the WDOG is enabled is going to cause a reset to the MCU if it is not refreshed.
B.R.
VaneB
