S32K144 TXERRCNT and RXERRCNT
已解决
跳至解决方案
3,192 次查看
Beautr
Do the TXERRCNT and RXERRCNT of the S32K144 CAN controller count automatically? Do we need code for any Settings?
1 解答
3,136 次查看
Senlent
Hi@Beautr
No, the count is automatically incremented if an error is encountered during normal operation
在原帖中查看解决方案
4 回复数
3,174 次查看
Beautr
When will the S32K144 go into freeze mode?
3,162 次查看
Senlent
Hi@Beautr
For flexcan module, lot of registers can only be read/write on Freeze mode.
for example,
Therefore, if you need to change the Flexcan reigster during normal operation, you should first see if you need to go into freeze mode.
3,156 次查看
Beautr
Hi, Senlent
    Thank you for your reply. I have one more question.
Are send and receive error counters automatically counted according to CAN2.0B specifications? Do we need code for any Settings?
3,137 次查看
Senlent
Hi@Beautr
