S32K144 PCB Layout Guidelines
x112233
I want to check the PCB design now, but I can't find any design guidelines in the specification.Can you provide me with the PCB design document for S32K144
thanks.
VaneB
Hi @x112233
In the application note AN5426: Hardware Design Guidelines for S32K1xx are provided the General board layout guidelines in section 10.
B.R.
VaneB
VaneB
Hi @x112233
B.R.
VaneB
AnhNguyenDuc
Hi @VaneB,
I want to measure the dimension between two headers on the board to make a adapter shield to connect with the board. Where can I find the these dimension ?
