S32K144 Flash Memory Programming Example code.
3,770 次查看
Jeevansagar
Hello, I wanted to program Flash memory in S32k144 using SDK.
I tried to get example code in the S32DS IDE, i got only the partitioning code i.e., flash_partitioning_s32k144.
Can anyone share me any tested Flash Programming code for S32K144?
标记 (2)
3,757 次查看
danielmartynek
Hi @Jeevansagar,
There is just the one SDK example you mentioned.
But it shows how to program the PFlash. If you don't want to partition the MCU, you can remove the code that does the partitioning and the code that writes and reads the EEPROM.
There are also the RTD drivers with this example: Ftfc_Ip_Example_S32K144
3,758 次查看
danielmartynek
Hi @Jeevansagar,
3,746 次查看
Jeevansagar
Alright, Thanks @danielmartynek
