S32K144 Flash Memory Programming Example code.
Jeevansagar
Hello, I wanted to program Flash memory in S32k144 using SDK.
I tried to get example code in the S32DS IDE, i got only the partitioning code i.e., flash_partitioning_s32k144.
Can anyone share me any tested Flash Programming code for S32K144?
danielmartynek
Hi @Jeevansagar,
There is just the one SDK example you mentioned.
But it shows how to program the PFlash. If you don't want to partition the MCU, you can remove the code that does the partitioning and the code that writes and reads the EEPROM.
There are also the RTD drivers with this example: Ftfc_Ip_Example_S32K144
danielmartynek
Hi @Jeevansagar,
Jeevansagar
Alright, Thanks @danielmartynek
