It is mentioned in the document that loading the secret key is to first calculate M1~M5, and then call the interface to load the secret key. M4_out and M5_out will be returned. By comparing M4, M5 and M4_out M5_out, If both are consistent, it indicates that the key has been successfully loaded, otherwise the loading fails. I found in actual testing that the loading interface returns 0, but M4, M5, M4_out, and M5_out are quite inconsistent. Is this considered a successful or failed loading?
