S32K142 controller EEPROM Read and Write source code
1,719件の閲覧回数
sureshm
Iam using S32K142 controller. Is there any source code available for EEPROM Read and Write operations.
Thank You,
1,712件の閲覧回数
danielmartynek
The flash_partitioning_s32k142 SDK example shows how to write the EEPROM.
The read/write operation is described in
AN11983 Using the S32K1xx EEPROM Functionality
3.6.1 EEE writes
3.6.2 EEE reads
https://www.nxp.com/docs/en/application-note/AN11983.pdf
