Freertos S32K144 Task cannot be scheduled
862908197
I am using FreeRTOS to run some tasks in my software on my S32K144 board, after start  vTaskStartScheduler() ,every task can be run only once, and stuck in idle task(portTASK_FUNCTION) as follow:
if( listCURRENT_LIST_LENGTH( &( pxReadyTasksLists[ tskIDLE_PRIORITY ] ) ) > ( UBaseType_t ) 1 )
 taskYIELD();//cant run here;
at the same time. i use the S32DS example project(freertos_s32k144) run in my board , The problem is the same。
the freertos config as follow:
Alexis_A
Hello @862908197 ,
Have you tried looking at the following document?
Also, could you share the code of the task that is not called again?
Alexis Andalon
