What is the meaning of “WDOG_IRQHandler() at startup_S32K116.S:169 0x46c ”?
And how can I fix it ? THX!
The program will end up in the DefaultISR endless while loop if an interrupt is fetched but its handler function is not implemented in the project.
It could be a fault exception.
Try adding Hard fault handler in you project:
void HardFault_Handler(void)
while(1){}
