S32K142 PWM Input
S32K142 PWM Input
Lauch_Spargel
is there a example where a PWM signal is received as input for the S32Kxx Series?
I can only find a post to the document AN5303 which I guess would be helpful if I could look at the attached sourcecode. But the link to that is not working anymore.
Has someone an example regarding PWM as Input?
Senlent
Hi@Lauch_Spargel
      I sent it to you privately, please check,
BR!
     Jim,
Senlent
Hi@Lauch_Spargel
Try thin link below, it works for me.
 https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
BR!
     Jim,
Lauch_Spargel
@Senlent
is it right, that this links to the software library?
Senlent
Hi@Lauch_Spargel
BR!
     Jim,
Lauch_Spargel
thank you
