S32K116 support bootloader by LIN communication
ganeshvaka2
Hi NXP
Customer is asking, can S32K116 support bootloader by LIN communication.
Do yo have demo code for S32K116 bootloader by LIN?
Note: Please give me any Suggestions
Ganesh Babu Vaka
lukaszadrapa
we have these two bootloaders supporting UART and CAN:
https://www.nxp.com/docs/en/application-note/AN12218.pdf
https://www.nxp.com/docs/en/application-note-software/AN12218SW.zip
https://www.nxp.com/docs/en/application-note/AN12323.pdf
https://www.nxp.com/docs/en/application-note-software/AN12323SW.zip
LIN could be used too but we do not have such SW example. An option is to modify these bootloaders.
Lukas
ganeshvaka2
Hello  @lukaszadrapa
Thank you for your valuable Response
we have a CAN-based Bootloader. we need to implement LIN based Bootloader for the same project. can we reuse CAN -TP  as a LIN TP
Can you please suggest to me How can I use LIN-TP via LIN Communication?
is there any difference between CAN-TP and LIN TP
Thank you
Ganesh Babu Vaka
