S32K116 support bootloader by LIN communication
2,035件の閲覧回数
ganeshvaka2
Hi NXP
Customer is asking, can S32K116 support bootloader by LIN communication.
Do yo have demo code for S32K116 bootloader by LIN?
Note: Please give me any Suggestions
Ganesh Babu Vaka
2 返答(返信)
2,017件の閲覧回数
lukaszadrapa
we have these two bootloaders supporting UART and CAN:
https://www.nxp.com/docs/en/application-note/AN12218.pdf
https://www.nxp.com/docs/en/application-note-software/AN12218SW.zip
https://www.nxp.com/docs/en/application-note/AN12323.pdf
https://www.nxp.com/docs/en/application-note-software/AN12323SW.zip
LIN could be used too but we do not have such SW example. An option is to modify these bootloaders.
Lukas
1,985件の閲覧回数
ganeshvaka2
Hello  @lukaszadrapa
Thank you for your valuable Response
we have a CAN-based Bootloader. we need to implement LIN based Bootloader for the same project. can we reuse CAN -TP  as a LIN TP
Can you please suggest to me How can I use LIN-TP via LIN Communication?
is there any difference between CAN-TP and LIN TP
Thank you
Ganesh Babu Vaka
