S32K116 LIN stack Init question
2,588件の閲覧回数
1090097669
after pin set PTC2-rxd,PTC3-txd,and lin stack --LIn_cfg set,pastedImage_2.png
and code blow:
l_sys_init();
l_ifc_init(LI0);
lin_trcv_init();
l_ifc_wake_up(LI0);
l_sys_irq_restore(LI0);
ld_init(LI0);
the question is I can not enter rx interrupt! why ? please help me to point the error,thank you。
2,412件の閲覧回数
Alexis_A
Hello Katrinal wang,
The l_ifc_init already sets the IRQ and the callback is used in the implementation of the stack. If you want to use the interruption you will need use the driver baremetal.
If you want to check where the interrupt is handled check the CallbackHandler in the lin.c file.
Alexis Andalon
2,413件の閲覧回数
Alexis_A
Alexis Andalon
