S32K unified bootloader
765077233
Hi Expert:
Could you please provide the Flash driver‘s source code to me?Because I only find bootloader's project from the website.Thanks!
PetrS
I'll send you a message.
BR, Petr
BobYan
Hi @765077233
Did you get the source code for Flash driver? If you did could you share it with me?  Thanks a lot.
arun_07
HI Petr,
Can you pls send me the S32K1XX bootloader source code.
TA, Arun
BobYan
Where to download the source code of bootloader which used by AN12218, S32K1xx Bootloader.
PetrS
BR, Petr
Fili
Hi PetrS,
Could you also please send me the sample code for the Unified bootloader?
I'm using the S32K144 and S32K146 MCU's
Thank you in advance,
Regards.
arun_07
HI Petr,
Can you pls send me that bootloader source code for S32K1XX?
Arun
