S32 design studio 3.6.4 compilation error
ソリューションへジャンプ
1,928件の閲覧回数
aaz1234
I am using S32 Design Studio 3.6.4 and attempting to flash the DIO example onto my RD-BESS1500BUN board for practice. The MCU on the board is S32K358, and I am using a J-Link debugger.
I installed the RTD S32K3xx drivers and integrated them into S32 Design Studio. After that, I imported the DIO example project provided with the RTD package. I opened the project’s .mex file in ConfigTools and generated/updated the code from there.
But i kept on getting these errors
タグ(1)
1,829件の閲覧回数
Senlent
Hi@aaz1234
This isn't a complicated issue.
I've already helped you resolve the compilation problems.
You should check yourself to ensure that the hardware you're using and the PIN used in the demo are compatible with your hardware.
7 返答(返信)
1,876件の閲覧回数
aaz1234
I did that and now I just deleted the example and reloaded it.
08:12:33 **** Incremental Build of configuration Debug_FLASH for project Dio_Example_S32K358 ****
make -j1 all
Building file: ../board/Tspc_Port_Ip_Cfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/Tspc_Port_Ip_Cfg.d" -MT"board/Tspc_Port_Ip_Cfg.o" -o "board/Tspc_Port_Ip_Cfg.o" "../board/Tspc_Port_Ip_Cfg.c"
Finished building: ../board/Tspc_Port_Ip_Cfg.c
Building file: ../RTD/src/Clock_Ip.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip.d" -MT"RTD/src/Clock_Ip.o" -o "RTD/src/Clock_Ip.o" "../RTD/src/Clock_Ip.c"
Finished building: ../RTD/src/Clock_Ip.c
Building file: ../RTD/src/Clock_Ip_Data.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Data.d" -MT"RTD/src/Clock_Ip_Data.o" -o "RTD/src/Clock_Ip_Data.o" "../RTD/src/Clock_Ip_Data.c"
Finished building: ../RTD/src/Clock_Ip_Data.c
Building file: ../RTD/src/Clock_Ip_Divider.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Divider.d" -MT"RTD/src/Clock_Ip_Divider.o" -o "RTD/src/Clock_Ip_Divider.o" "../RTD/src/Clock_Ip_Divider.c"
Finished building: ../RTD/src/Clock_Ip_Divider.c
Building file: ../RTD/src/Clock_Ip_DividerTrigger.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_DividerTrigger.d" -MT"RTD/src/Clock_Ip_DividerTrigger.o" -o "RTD/src/Clock_Ip_DividerTrigger.o" "../RTD/src/Clock_Ip_DividerTrigger.c"
Finished building: ../RTD/src/Clock_Ip_DividerTrigger.c
Building file: ../RTD/src/Clock_Ip_ExtOsc.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_ExtOsc.d" -MT"RTD/src/Clock_Ip_ExtOsc.o" -o "RTD/src/Clock_Ip_ExtOsc.o" "../RTD/src/Clock_Ip_ExtOsc.c"
Finished building: ../RTD/src/Clock_Ip_ExtOsc.c
Building file: ../RTD/src/Clock_Ip_FracDiv.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_FracDiv.d" -MT"RTD/src/Clock_Ip_FracDiv.o" -o "RTD/src/Clock_Ip_FracDiv.o" "../RTD/src/Clock_Ip_FracDiv.c"
Finished building: ../RTD/src/Clock_Ip_FracDiv.c
Building file: ../RTD/src/Clock_Ip_Frequency.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Frequency.d" -MT"RTD/src/Clock_Ip_Frequency.o" -o "RTD/src/Clock_Ip_Frequency.o" "../RTD/src/Clock_Ip_Frequency.c"
Finished building: ../RTD/src/Clock_Ip_Frequency.c
Building file: ../RTD/src/Clock_Ip_Gate.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Gate.d" -MT"RTD/src/Clock_Ip_Gate.o" -o "RTD/src/Clock_Ip_Gate.o" "../RTD/src/Clock_Ip_Gate.c"
Finished building: ../RTD/src/Clock_Ip_Gate.c
Building file: ../RTD/src/Clock_Ip_IntOsc.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_IntOsc.d" -MT"RTD/src/Clock_Ip_IntOsc.o" -o "RTD/src/Clock_Ip_IntOsc.o" "../RTD/src/Clock_Ip_IntOsc.c"
Finished building: ../RTD/src/Clock_Ip_IntOsc.c
Building file: ../RTD/src/Clock_Ip_Irq.c
0 [main] make (5492) child_copy: cygheap read copy failed, 0x0..0x80002A480, done 0, windows pid 5492, Win32 error 299
0 [main] make 1067 dofork: child -1 - forked process 5492 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
make: *** [RTD/src/subdir.mk:157: RTD/src/Clock_Ip_Irq.o] Error 127
"make -j1 all" terminated with exit code 2. Build might be incomplete.
08:12:39 Build Failed. 1 errors, 0 warnings. (took 6s.336ms)
1,867件の閲覧回数
Senlent
Hi@aaz1234
Based on this information, it seems to be a problem with your computer, most commonly caused by antivirus/security software interfering with a fork on Windows.
1,857件の閲覧回数
aaz1234
I have tried with my personal laptop, its now building without errors and i have debugged it as well. but the LED is still not blinking... I used this setting
1,830件の閲覧回数
Senlent
Hi@aaz1234
1,880件の閲覧回数
aaz1234
I’m using RTD 3.0.0 (AUTOSAR 4.7.0) on S32DS 3.6.4 This is the version i am using
And thats the error.
14:00:56 **** Incremental Build of configuration Debug_FLASH for project Dio_Example_S32K358 ****
make -j1 all
Building file: ../Project_Settings/Startup_Code/system.c
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/system.d" -MT"Project_Settings/Startup_Code/system.o" -o "Project_Settings/Startup_Code/system.o" "../Project_Settings/Startup_Code/system.c"
../Project_Settings/Startup_Code/system.c:46:10: fatal error: Platform_Types.h: No such file or directory
46 | #include "Platform_Types.h"
compilation terminated.
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/system.o] Error 1
14:01:02 Build Failed. 2 errors, 0 warnings. (took 6s.216ms)
I was having another error during building the project and it was related to parallel build so i disable parallel build and chose these conf. but now it is gone
1,878件の閲覧回数
Senlent
Hi@aaz1234
"fatal error: Platform_Types.h: No such file or directory"
The error message indicates a missing file. Are you sure you clicked the "Update Code" to generate the configuration file?
1,887件の閲覧回数
Senlent
Hi@aaz1234
please tell me the RTD version you're using and could you please provide the error message in the screenshot.
%3CLINGO-SUB%20id%3D%22lingo-sub-2337623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%203.6.4%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFS32%20Design%20Studio%203.6.4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%B7%B4%E7%BF%92%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81DIO%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92RD-BESS1500BUN%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%9F%BA%E6%9D%BF%E4%B8%8A%E3%81%AEMCU%E3%81%AFS32K358%E3%81%A7%E3%80%81J-Link%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERTD%20S32K3xx%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81S32%20Design%20Studio%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81RTD%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BDIO%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ConfigTools%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%2F%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380078i21F8F0EE9A2152BD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.PNG%22%20alt%3D%22Capture.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%40%20%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CU%3E0%20%5Bmain%5D%20make%201067%20dofork%3A%20%E5%AD%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20-1%20-%3CSTRONG%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%3C%2FSTRONG%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%205492%20%E3%81%8C%E4%BA%88%E6%9C%9F%E3%81%9B%E3%81%9A%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%200%E3%80%81%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%200xC0000142%E3%80%81errno%2011%3C%2FU%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%81%A8%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A4%E3%83%AB%E3%82%B9%E5%AF%BE%E7%AD%96%E3%82%BD%E3%83%95%E3%83%88%E3%82%84%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%BD%E3%83%95%E3%83%88%E3%81%8CWindows%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E5%87%A6%E7%90%86%E3%82%92%E5%A6%A8%E5%AE%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E5%86%8D%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E08%3A12%3A33%20****%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20Dio_Example_S32K358%20%E3%81%AE%E6%A7%8B%E6%88%90%20Debug_FLASH%20%E3%81%AE%E5%A2%97%E5%88%86%E3%83%93%E3%83%AB%E3%83%89%20****%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%20-j1%20all%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fboard%2FTspc_Port_Ip_Cfg.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22-MMD%20-MP%20-MF%22board%2FTspc_Port_Ip_Cfg.d%22-MT%22board%2FTspc_Port_Ip_Cfg.o%22-o%20%22board%2FTspc_Port_Ip_Cfg.o%22%22..%2Fboard%2FTspc_Port_Ip_Cfg.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2Fboard%2FTspc_Port_Ip_Cfg.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Data.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Data.d%22-MT%22RTD%2Fsrc%2FClock_Ip_Data.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_Data.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_Data.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Data.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Divider.d%22-MT%22RTD%2Fsrc%2FClock_Ip_Divider.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_Divider.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.d%22-MT%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_ExtOsc.d%22-MT%22RTD%2Fsrc%2FClock_Ip_ExtOsc.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_ExtOsc.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_FracDiv.d%22-MT%22RTD%2Fsrc%2FClock_Ip_FracDiv.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_FracDiv.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Frequency.d%22-MT%22RTD%2Fsrc%2FClock_Ip_Frequency.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_Frequency.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Gate.d%22-MT%22RTD%2Fsrc%2FClock_Ip_Gate.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_Gate.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_IntOsc.d%22-MT%22RTD%2Fsrc%2FClock_Ip_IntOsc.o%22-o%20%22RTD%2Fsrc%2FClock_Ip_IntOsc.o%22%22..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E5%AE%8C%E4%BA%86%3A%20..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Irq.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0%20%5Bmain%5D%20make%20(5492)%20child_copy%3A%20cygheap%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%810x0..0x80002A480%E3%80%81%E5%AE%8C%E4%BA%86%200%E3%80%81Windows%20PID%205492%E3%80%81Win32%20%E3%82%A8%E3%83%A9%E3%83%BC%20299%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0%20%5Bmain%5D%20make%201067%20dofork%3A%20%E5%AD%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20-1%20-%20%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%205492%20%E3%81%8C%E4%BA%88%E6%9C%9F%E3%81%9B%E3%81%9A%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E5%9B%9E%E6%95%B0%200%E3%80%81%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%200xC0000142%E3%80%81errno%2011%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%3A%20***%20%5BRTD%2Fsrc%2Fsubdir.mk%3A157%3ARTD%2Fsrc%2FClock_Ip_Irq.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20127%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8Cmake%20-j1%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E08%3A12%3A39%20%E3%83%93%E3%83%AB%E3%83%89%E5%A4%B1%E6%95%97%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC1%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%80%82%EF%BC%88%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%EF%BC%9A6%E7%A7%92336%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380161iD200CDBE591EF894%2Fimage-dimensions%2F925x564%3Fv%3Dv2%22%20width%3D%22925%22%20height%3D%22564%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-03-24%20081519.png%22%20alt%3D%22Screenshot%202026-03-24%20081519.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%40%20%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%80%8C%3CSPAN%3E%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Platform_Types.h%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFRTD%203.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(AUTOSAR%204.7.0)%20on%20S32DS%203.6.4%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E14%3A00%3A56%20****%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20Dio_Example_S32K358%20%E3%81%AE%E6%A7%8B%E6%88%90%20Debug_FLASH%20%E3%81%AE%E5%A2%97%E5%88%86%E3%83%93%E3%83%AB%E3%83%89%20****%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%20-j1%20all%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E4%B8%AD%3A%20..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fsystem.d%22-MT%22Project_Settings%2FStartup_Code%2Fsystem.o%22-o%20%22Project_Settings%2FStartup_Code%2Fsystem.o%22%22..%2FProject_Settings%2FStartup_Code%2Fsystem.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3A46%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Platform_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E46%20%7C%20%23include%20%22Platform_Types.h%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7C%20%5E~~~~~~~~~~~~~~~~~%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3AProject_Settings%2FStartup_Code%2Fsystem.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8Cmake%20-j1%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E14%3A01%3A02%20%E3%83%93%E3%83%AB%E3%83%89%E5%A4%B1%E6%95%97%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC2%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%80%82%EF%BC%88%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%EF%BC%9A6%E7%A7%92216%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E5%88%A5%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E4%B8%A6%E5%88%97%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E4%B8%A6%E5%88%97%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E4%BB%8A%E3%81%AF%E3%82%82%E3%81%86%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%A3%E3%81%9F%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380153iE9C3763B552156A3%2Fimage-dimensions%2F745x550%3Fv%3Dv2%22%20width%3D%22745%22%20height%3D%22550%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-03-24%20075143.png%22%20alt%3D%22Screenshot%202026-03-24%20075143.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%40%20%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BRTD%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%40%20%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E8%A4%87%E9%9B%91%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%97%A2%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%AE%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%A2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8PIN%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%80%81%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%80%81%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E8%87%AA%E5%88%86%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%88PC%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%82%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LED%E3%81%AF%E3%81%BE%E3%81%A0%E7%82%B9%E6%BB%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93...%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Debug%20config..png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Debug%20config..png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380199iB60AEBF8276A7762%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Debug%20config..png%22%20alt%3D%22Debug%20config..png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
