S32 design studio 3.6.4 compilation error
aaz1234
I am using S32 Design Studio 3.6.4 and attempting to flash the DIO example onto my RD-BESS1500BUN board for practice. The MCU on the board is S32K358, and I am using a J-Link debugger.
I installed the RTD S32K3xx drivers and integrated them into S32 Design Studio. After that, I imported the DIO example project provided with the RTD package. I opened the project’s .mex file in ConfigTools and generated/updated the code from there.
But i kept on getting these errors
Senlent
Hi@aaz1234
This isn't a complicated issue.
I've already helped you resolve the compilation problems.
You should check yourself to ensure that the hardware you're using and the PIN used in the demo are compatible with your hardware.
aaz1234
I did that and now I just deleted the example and reloaded it.
08:12:33 **** Incremental Build of configuration Debug_FLASH for project Dio_Example_S32K358 ****
make -j1 all
Building file: ../board/Tspc_Port_Ip_Cfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/Tspc_Port_Ip_Cfg.d" -MT"board/Tspc_Port_Ip_Cfg.o" -o "board/Tspc_Port_Ip_Cfg.o" "../board/Tspc_Port_Ip_Cfg.c"
Finished building: ../board/Tspc_Port_Ip_Cfg.c
Building file: ../RTD/src/Clock_Ip.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip.d" -MT"RTD/src/Clock_Ip.o" -o "RTD/src/Clock_Ip.o" "../RTD/src/Clock_Ip.c"
Finished building: ../RTD/src/Clock_Ip.c
Building file: ../RTD/src/Clock_Ip_Data.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Data.d" -MT"RTD/src/Clock_Ip_Data.o" -o "RTD/src/Clock_Ip_Data.o" "../RTD/src/Clock_Ip_Data.c"
Finished building: ../RTD/src/Clock_Ip_Data.c
Building file: ../RTD/src/Clock_Ip_Divider.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Divider.d" -MT"RTD/src/Clock_Ip_Divider.o" -o "RTD/src/Clock_Ip_Divider.o" "../RTD/src/Clock_Ip_Divider.c"
Finished building: ../RTD/src/Clock_Ip_Divider.c
Building file: ../RTD/src/Clock_Ip_DividerTrigger.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_DividerTrigger.d" -MT"RTD/src/Clock_Ip_DividerTrigger.o" -o "RTD/src/Clock_Ip_DividerTrigger.o" "../RTD/src/Clock_Ip_DividerTrigger.c"
Finished building: ../RTD/src/Clock_Ip_DividerTrigger.c
Building file: ../RTD/src/Clock_Ip_ExtOsc.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_ExtOsc.d" -MT"RTD/src/Clock_Ip_ExtOsc.o" -o "RTD/src/Clock_Ip_ExtOsc.o" "../RTD/src/Clock_Ip_ExtOsc.c"
Finished building: ../RTD/src/Clock_Ip_ExtOsc.c
Building file: ../RTD/src/Clock_Ip_FracDiv.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_FracDiv.d" -MT"RTD/src/Clock_Ip_FracDiv.o" -o "RTD/src/Clock_Ip_FracDiv.o" "../RTD/src/Clock_Ip_FracDiv.c"
Finished building: ../RTD/src/Clock_Ip_FracDiv.c
Building file: ../RTD/src/Clock_Ip_Frequency.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Frequency.d" -MT"RTD/src/Clock_Ip_Frequency.o" -o "RTD/src/Clock_Ip_Frequency.o" "../RTD/src/Clock_Ip_Frequency.c"
Finished building: ../RTD/src/Clock_Ip_Frequency.c
Building file: ../RTD/src/Clock_Ip_Gate.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_Gate.d" -MT"RTD/src/Clock_Ip_Gate.o" -o "RTD/src/Clock_Ip_Gate.o" "../RTD/src/Clock_Ip_Gate.c"
Finished building: ../RTD/src/Clock_Ip_Gate.c
Building file: ../RTD/src/Clock_Ip_IntOsc.c
arm-none-eabi-gcc "@RTD/src/Clock_Ip.args" -MMD -MP -MF"RTD/src/Clock_Ip_IntOsc.d" -MT"RTD/src/Clock_Ip_IntOsc.o" -o "RTD/src/Clock_Ip_IntOsc.o" "../RTD/src/Clock_Ip_IntOsc.c"
Finished building: ../RTD/src/Clock_Ip_IntOsc.c
Building file: ../RTD/src/Clock_Ip_Irq.c
0 [main] make (5492) child_copy: cygheap read copy failed, 0x0..0x80002A480, done 0, windows pid 5492, Win32 error 299
0 [main] make 1067 dofork: child -1 - forked process 5492 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
make: *** [RTD/src/subdir.mk:157: RTD/src/Clock_Ip_Irq.o] Error 127
"make -j1 all" terminated with exit code 2. Build might be incomplete.
08:12:39 Build Failed. 1 errors, 0 warnings. (took 6s.336ms)
Senlent
Hi@aaz1234
Based on this information, it seems to be a problem with your computer, most commonly caused by antivirus/security software interfering with a fork on Windows.
aaz1234
I have tried with my personal laptop, its now building without errors and i have debugged it as well. but the LED is still not blinking... I used this setting
Senlent
Hi@aaz1234
aaz1234
I’m using RTD 3.0.0 (AUTOSAR 4.7.0) on S32DS 3.6.4 This is the version i am using
And thats the error.
14:00:56 **** Incremental Build of configuration Debug_FLASH for project Dio_Example_S32K358 ****
make -j1 all
Building file: ../Project_Settings/Startup_Code/system.c
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/system.d" -MT"Project_Settings/Startup_Code/system.o" -o "Project_Settings/Startup_Code/system.o" "../Project_Settings/Startup_Code/system.c"
../Project_Settings/Startup_Code/system.c:46:10: fatal error: Platform_Types.h: No such file or directory
46 | #include "Platform_Types.h"
compilation terminated.
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/system.o] Error 1
14:01:02 Build Failed. 2 errors, 0 warnings. (took 6s.216ms)
I was having another error during building the project and it was related to parallel build so i disable parallel build and chose these conf. but now it is gone
Senlent
Hi@aaz1234
"fatal error: Platform_Types.h: No such file or directory"
The error message indicates a missing file. Are you sure you clicked the "Update Code" to generate the configuration file?
Senlent
Hi@aaz1234
please tell me the RTD version you're using and could you please provide the error message in the screenshot.
%3CLINGO-SUB%20id%3D%22lingo-sub-2337623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20using%20S32%20Design%20Studio%203.6.4%20and%20attempting%20to%20flash%20the%20DIO%20example%20onto%20my%20RD-BESS1500BUN%20board%20for%20practice.%20The%20MCU%20on%20the%20board%20is%20S32K358%2C%20and%20I%20am%20using%20a%20J-Link%20debugger.%3C%2FP%3E%3CP%3EI%20installed%20the%20RTD%20S32K3xx%20drivers%20and%20integrated%20them%20into%20S32%20Design%20Studio.%20After%20that%2C%20I%20imported%20the%20DIO%20example%20project%20provided%20with%20the%20RTD%20package.%20I%20opened%20the%20project%E2%80%99s%20.mex%20file%20in%20ConfigTools%20and%20generated%2Fupdated%20the%20code%20from%20there.%26nbsp%3B%3CBR%20%2F%3EBut%20i%20kept%20on%20getting%20these%20errors%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380078i21F8F0EE9A2152BD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.PNG%22%20alt%3D%22Capture.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CU%3E0%20%5Bmain%5D%20make%201067%20dofork%3A%20child%20-1%20-%20%3CSTRONG%3Eforked%3C%2FSTRONG%3E%20process%205492%20died%20unexpectedly%2C%20retry%200%2C%20exit%20code%200xC0000142%2C%20errno%2011%3C%2FU%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBased%20on%20this%20information%2C%20it%20seems%20to%20be%20a%20problem%20with%20your%20computer%2C%20most%20commonly%20caused%20by%20antivirus%2Fsecurity%20software%20interfering%20with%20a%20fork%20on%20Windows.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20did%20that%20and%20now%20I%20just%20deleted%20the%20example%20and%20reloaded%20it.%26nbsp%3B%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E08%3A12%3A33%20****%20Incremental%20Build%20of%20configuration%20Debug_FLASH%20for%20project%20Dio_Example_S32K358%20****%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%20-j1%20all%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2Fboard%2FTspc_Port_Ip_Cfg.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22board%2FTspc_Port_Ip_Cfg.d%22%20-MT%22board%2FTspc_Port_Ip_Cfg.o%22%20-o%20%22board%2FTspc_Port_Ip_Cfg.o%22%20%22..%2Fboard%2FTspc_Port_Ip_Cfg.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2Fboard%2FTspc_Port_Ip_Cfg.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Data.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Data.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_Data.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_Data.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_Data.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Data.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Divider.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_Divider.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_Divider.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Divider.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_DividerTrigger.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_DividerTrigger.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_ExtOsc.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_ExtOsc.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_ExtOsc.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_ExtOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_FracDiv.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_FracDiv.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_FracDiv.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_FracDiv.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Frequency.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_Frequency.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_Frequency.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Frequency.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_Gate.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_Gate.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_Gate.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Gate.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40RTD%2Fsrc%2FClock_Ip.args%22%20-MMD%20-MP%20-MF%22RTD%2Fsrc%2FClock_Ip_IntOsc.d%22%20-MT%22RTD%2Fsrc%2FClock_Ip_IntOsc.o%22%20-o%20%22RTD%2Fsrc%2FClock_Ip_IntOsc.o%22%20%22..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFinished%20building%3A%20..%2FRTD%2Fsrc%2FClock_Ip_IntOsc.c%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FRTD%2Fsrc%2FClock_Ip_Irq.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0%20%5Bmain%5D%20make%20(5492)%20child_copy%3A%20cygheap%20read%20copy%20failed%2C%200x0..0x80002A480%2C%20done%200%2C%20windows%20pid%205492%2C%20Win32%20error%20299%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0%20%5Bmain%5D%20make%201067%20dofork%3A%20child%20-1%20-%20forked%20process%205492%20died%20unexpectedly%2C%20retry%200%2C%20exit%20code%200xC0000142%2C%20errno%2011%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%3A%20***%20%5BRTD%2Fsrc%2Fsubdir.mk%3A157%3A%20RTD%2Fsrc%2FClock_Ip_Irq.o%5D%20Error%20127%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%22make%20-j1%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E08%3A12%3A39%20Build%20Failed.%201%20errors%2C%200%20warnings.%20(took%206s.336ms)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20081519.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380161iD200CDBE591EF894%2Fimage-dimensions%2F925x564%3Fv%3Dv2%22%20width%3D%22925%22%20height%3D%22564%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-03-24%20081519.png%22%20alt%3D%22Screenshot%202026-03-24%20081519.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%22%3CSPAN%3Efatal%20error%3A%20Platform_Types.h%3A%20No%20such%20file%20or%20directory%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThe%20error%20message%20indicates%20a%20missing%20file.%20Are%20you%20sure%20you%20clicked%20the%20%22Update%20Code%22%20to%20generate%20the%20configuration%20file%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%E2%80%99m%20using%20RTD%203.0.0%20(AUTOSAR%204.7.0)%20on%20S32DS%203.6.4%20This%20is%20the%20version%20i%20am%20using%3C%2FP%3E%3CP%3EAnd%20thats%20the%20error.%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E14%3A00%3A56%20****%20Incremental%20Build%20of%20configuration%20Debug_FLASH%20for%20project%20Dio_Example_S32K358%20****%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%20-j1%20all%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22%20-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fsystem.d%22%20-MT%22Project_Settings%2FStartup_Code%2Fsystem.o%22%20-o%20%22Project_Settings%2FStartup_Code%2Fsystem.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fsystem.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3A46%3A10%3A%20fatal%20error%3A%20Platform_Types.h%3A%20No%20such%20file%20or%20directory%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E46%20%7C%20%23include%20%22Platform_Types.h%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7C%20%5E~~~~~~~~~~~~~~~~~%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ecompilation%20terminated.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%20Project_Settings%2FStartup_Code%2Fsystem.o%5D%20Error%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%22make%20-j1%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E14%3A01%3A02%20Build%20Failed.%202%20errors%2C%200%20warnings.%20(took%206s.216ms)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EI%20was%20having%20another%20error%20during%20building%20the%20project%20and%20it%20was%20related%20to%20parallel%20build%20so%20i%20disable%20parallel%20build%20and%20chose%20these%20conf.%20but%20now%20it%20is%20gone%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-03-24%20075143.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380153iE9C3763B552156A3%2Fimage-dimensions%2F745x550%3Fv%3Dv2%22%20width%3D%22745%22%20height%3D%22550%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-03-24%20075143.png%22%20alt%3D%22Screenshot%202026-03-24%20075143.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eplease%20tell%20me%20the%20RTD%20version%20you're%20using%20and%20could%20you%20please%20provide%20the%20error%20message%20in%20the%20screenshot.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Eaaz1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20isn't%20a%20complicated%20issue.%3C%2FP%3E%0A%3CP%3EI've%20already%20helped%20you%20resolve%20the%20compilation%20problems.%3C%2FP%3E%0A%3CP%3EYou%20should%20check%20yourself%20to%20ensure%20that%20the%20hardware%20you're%20using%20and%20the%20PIN%20used%20in%20the%20demo%20are%20compatible%20with%20your%20hardware.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20design%20studio%203.6.4%20compilation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20have%20tried%20with%20my%20personal%20laptop%2C%20its%20now%20building%20without%20errors%20and%20i%20have%20debugged%20it%20as%20well.%20but%20the%20LED%20is%20still%20not%20blinking...%20I%20used%20this%20setting%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Debug%20config..png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Debug%20config..png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380199iB60AEBF8276A7762%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Debug%20config..png%22%20alt%3D%22Debug%20config..png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
