Regarding External Flash writing issue
1,436 次查看
Pragadeesh
I am using S32K342 variant chip , in that i want to write data in External flash through QSPI, for that I am using FLS module from the RTD package SW32K3_RTD_4.4_2.0.0 , actually i can able to erase , read and write, but writing is not happening the proper order, i can see the 1st 4 bytes of data is swapped to last of the initialized buffer, for more information i have attached the picture.
Thanks & Regards,
Pragadeesh
1 回复
1,423 次查看
davidtosenovjan
Do you see this failure also over AHB read?
