Problem with connecting to S32K146 EVB using USB cable
HGln
I have a S32K146 EVB, and nothing happens when I connect the board to my PC using the USB cable (the board does not power up and is not recognized as an MSC device). I think there is a problem with openSDA MK20DX128VFM5. Is there any way that I can reprogram it and make it work?
Hope for your support
Julián_AragónM
Hi @HGln,
Please follow this guide on how to update the SDA Firmware, and try to connect it again:
Also, make sure the jumpers are configured as default (you can use S32K146 EVB Quick Start Guide as reference).
Julián
Julián_AragónM
Hi @HGln,
Julián
