S32K344 FreeRTOS MQTTS mbedTLS HSE Example?
ソリューションへジャンプ
8,754件の閲覧回数
ChrisFurlough
Hello all.
I'm running FreeRTOS on an S32K344, and I'm trying to find an example build that uses MQTTS (MQTT over TLS) using the mbedTLS stack incorporating the NXP HSE.  I've found bits and pieces around, but trying to integrate them all together is nothing short of a nightmare.  You have includes from THIS package, that package, the FW, and trying to get all the files in the right places, and all the include paths setup, it's just maddening.
"It's always something!"
Is there a package/example somewhere that includes all of these that compiles?
8,691件の閲覧回数
CongDang
I tried searching and contacting several projects but unfortunately we don't have such a package/example available!
3 返答(返信)
8,278件の閲覧回数
IoanaDinu
Hello!
You can find here (https://www.nxp.com/document/guide/getting-started-with-aws-libraries-for-s32k3:GS-AWS-LIBRARIES-S32...) a step by step tutorial for getting and installing the software for AWS Libraries for S32K3 product.
In this project you can find a Simple MQTT Demo example in which the mbedTLS encryption is used with NXP HSE. Also, this product is running FreeRTOS.
I hope that it is similar to what you are looking for on S32K344.
8,692件の閲覧回数
CongDang
8,678件の閲覧回数
ChrisFurlough
Well, if your developers get bored, that's certainly something to consider as a project for them.
