Problem regarding mscr register issue in S32K SDK version 4
1,689件の閲覧回数
abdul_rahman
Hi NXP team,
I've made a complimentary PWM program for S32K344 microcontroller in the version 3 SDK for the same. But, when I'm opening the project in version 4 of the same SDK, it is giving an error that the "MSCR register value is not set in the pins tool". The error message is given below.
I would like to know about where I can set the MSCR value in the pins configuration tool.
P.S.: Can you also guide me in opening my entire version 3 made project in a version 4 SDK without the compiler giving any errors? It would really save my time in making the entire project again in the new version.
#S32K344 #emios #LCU #TRGMUX #PWM
2 返答(返信)
1,609件の閲覧回数
jiri_kral
Hello Abdul,
it is possible share your working project for RTM v3.0.0? I'll try to figure out how to migrate it in RTM v4.0.0
1,381件の閲覧回数
abdul_rahman
Hi @jiri_kral
I have attached the project file in 3.0.0 version
P.S.: What about the solution to the mscr register problem?
