Hello, i want to use icu to Implement PWM capture. I've added the emios_icu module and updated the code, but I found that the global variables and functions in the RTD/SRC/Emios_Icu_Ip.c and RTD/SRC/Emios_Icu_Ip.h files are all showing as undefined, which prevents me from calling Emios_Icu_Ip_Init to initialize the icu channel. Could you please help me look into this?
