PCFS -- Amax calculation
1,602 次查看
zhiguoguo
hello,
in my point,
"Config->MaxAllowableIDDchange" indicates that Maximum variation of current per time (mA/microsec).
"CLOCK_IP_DYNAMIC_IDD_CHANGE" indicates that variation of current per MHZz(microA / MHz).
"Config->StepDuration * Config->MaxAllowableIDDchange" indicates the variation of current.
Why CLOCK_IP_DIVIDE_BY_100000 is 100,000 not 1,000,000?
look forward to your response~
1,582 次查看
DanNguyenDuy
Hello zhiguoguo,
What is the package you are using?
And what is the module's name contains this file?
Dan
标记 (1)
