OpenBus
geoff_roy
Is Openbus.exe compatible with Vector 1630A CAN device?? I don-t have a P-CAN device with me, but has a Vector 1630A CAN device. Will that be a challenge. @dianabatrlova
lukaszadrapa
Hi Geoff,
I expect that any PCAN-USB... can be used but I will ask to be sure.
Lukas
HayZam
How should the physical connection be for using OpenBus.exe with LIN  and S32K116EVB?
Is connecting pin 7 (LIN) and pin 3 (GND) to the EVB enough?
Is any extra configuration required to use this tool?
HayZam
lukaszadrapa
I'm afraid that P-CAN is currently the only option.
Lukas
geoff_roy
Hi Lukas,
Could you please help me with the version or specific device name to be purchased for easy use of Openbus software.
Thanks and Regards,
Geoff
lukaszadrapa
Hi Geoff,
I was told that all PCAN USB devices should be detected and identified by OpenBus SW.
It was tested with basic PCAN-USB.
Hope this helps.
Lukas
lukaszadrapa
Hi Geoff,
Lukas
DBD
Hi Lukaszadrapa
I wan to use OpenBus but i don 't have Peak can adapter, i have a other USB-CAN adapter. so how to modify OpenBus to compatible other adapter. thanks
geoff_roy
Thanks for your input.
