NXP S32K118 Q048 Evaulation board documentation.
1,712 次查看
yousefdessouki123
For the S32K118 Q048 Package, I can not find the Q048 pin layout in the refernce layout.
https://www.nxp.com/docs/en/quick-reference-guide/S32K118EVB-QSG.pdf
标记 (1)
1,702 次查看
petervlna
1,677 次查看
yousefdessouki123
Thanks for the response. However, I am looking for the header pinout layout. In the user guide, it is all about NXPS32K118Q064 not for NXPS32K118Q048. Kindly refer to the picture I have attached. I am looking for something similiar to it but for the Q048 package.
1,641 次查看
petervlna
Both use the same guide:
The differences on the pins you can find in the reference manual IO mux table for S32K118:
If the 48LQFP is missing pins compared to 64LQFP then it wont be also routed on the EVB, simply as it is not routed from micro IP to its package.
Peter
"apologize for delay, I was out due sickness"
1,703 次查看
petervlna
