Our project configure SMR for secure boot feature in CUST_DEL using plain-text AES key slot owner by HSE_KEY_OWNER_CUST.
The SMR is configured in CUST_DEL and secure boot feature works normal in CUST_DEL.
Is there any impacts on secure boot feature after the HSE lifeCycle advanced to IN_FIELD?
解決済! 解決策の投稿を見る。
Generally, restrictions given by life cycle target rather key management than key usage. So, there won't be difference in this case if you advance the life cycle to IN_FIELD.
Lukas
Lukas
