MotorGD
Abdel
Hello, can you help me? When I connect DEVKIT-MOTORGD to the S32K144, the lamp on the power supply unit and the LED start to flash before and also led in front of the Hallo Encoder Interface. Is the circuit board defect now? can I repair it?
Thanks in advance
petervlna
Did you followed our guide? : Get Started with DEVKIT-MOTORGD motor control shield
https://www.nxp.com/document/guide/get-started-with-the-devkit-motorgd:NGS-DEVKIT-MOTORGD
best regards,
Peter
petervlna
best regards,
Peter
Abdel
Hi, thank you for your answer. Yes i followed a guid. I think the motor board ist defect. do you have a circuit diagramm for the motor board. Thank you in advance
best regards Abdel
