MotorGD
2,140件の閲覧回数
Abdel
Hello, can you help me? When I connect DEVKIT-MOTORGD to the S32K144, the lamp on the power supply unit and the LED start to flash before and also led in front of the Hallo Encoder Interface. Is the circuit board defect now? can I repair it?
Thanks in advance
2,133件の閲覧回数
petervlna
Did you followed our guide? : Get Started with DEVKIT-MOTORGD motor control shield
https://www.nxp.com/document/guide/get-started-with-the-devkit-motorgd:NGS-DEVKIT-MOTORGD
best regards,
Peter
2 返答(返信)
2,134件の閲覧回数
petervlna
best regards,
Peter
2,126件の閲覧回数
Abdel
Hi, thank you for your answer. Yes i followed a guid. I think the motor board ist defect. do you have a circuit diagramm for the motor board. Thank you in advance
best regards Abdel
