MTRDEVKSPNK144-Debug error, please help
已解决
跳至解决方案
6,425 次查看
fuyanchao
Hi there,
I bought a S32K144 development kit  MTRDEVKSPNK144, and I tried to operate the kit to rotate the PMSM motor, I followed every instruction in the document Quick Start Guide MTRDEVKSPNK144 S32K144 Development Kit for 3-phase PMSM , but in the step 9 (Debug the code), I encounter a problem, as the pic below
When I click Proceed, then S32 said, Program file does not exist, as the pic below
I tried to search the file ‘MTRDEVKSPNK144_DualShunt.elf’ on my disc, but there is none.
Could anyone help me to solve this problem?
Thanks a lot!
标签 (1)
标记 (1)
1 解答
6,178 次查看
dianabatrlova
Could you, please, check where this file 'freemaster_appcmd.c' is located in your file system?
This file is expected on this file path. I assume that you have it at a different place.
C:/NXP/S32DS_ARM_v2018.R1/S32DS/FreeMASTER_Serial_Communication_Driver_V2_0/src_common/freemaster_appcmd.c
Diana
在原帖中查看解决方案
7 回复数
6,178 次查看
dianabatrlova
Your .elf is not generated because you have an error in your project. I assume that your errors will be related to the AMMCLIB path. This path should be changed, this is described in community thread below:
https://community.nxp.com/message/1267056?commentID=1267056#comment-1267056
I believe it helps.
Diana
6,178 次查看
fuyanchao
Dear Diana,
 Thanks for your reply!
I followed the instructions you told me, as the pics below
But it still doesn't work.
Every time I tried to debug the example project, S32 always stuck at 'Launching : Build before launch - invoking Command: make -j8',
And after several minutes, it failed,
At last, the same error happened, do you know why?
Thanks a lot in advance!
6,178 次查看
dianabatrlova
Please, delete the older one paths and clean the project (right-click on the project -> Clean project)
Also, please, just build your project (right-click on the project -> Build project) and show me the errors located in the "Problems" tab.
Thank you.
Diana
6,178 次查看
fuyanchao
Dear Diana,
It's really nice to hear from you, I am torturing by this error, really drive me crazy!
Please see the picture below, as your instruction.
The error is 'Description Resource Path Location Type make: *** No rule to make target C:/NXP/S32DS_ARM_v2018.R1/S32DS/FreeMASTER_Serial_Communication_Driver_V2_0/src_common/freemaster_appcmd.c', needed by 'FreeMaster_S32xx/src_common/freemaster_appcmd.o'. Stop. MTRDEVKSPNK144_DualShunt C/C++ Problem'
I know it is quiet late in your time zone, and I really thank you very much.
6,178 次查看
dianabatrlova
Diana
6,178 次查看
fuyanchao
Hello, Diana,
I added the missing file, but while I was trying to debug the code, another error occurred, S32 said 'Could not determine GDB version after sending: D:\NXP\S32DS_ARM_v2018.R1\eclipse\../Cross_Tools/gcc-6.3-arm32-eabi/bin/arm-none-eabi-gdb --version, response: '
Do you know how to solve this problem?
Thanks you in advance!
6,178 次查看
dianabatrlova
Instead of trying to add the missing file at that location. I assume you just need to change the file path in the properties of the project.
So, please, select the correct paths to these files:
Next time when you select the default location during the installation of S32Design Studio you will avoid these issues.
Diana
