LPIT GPT documentation missing
106件の閲覧回数
daniel_meier
I'd like to use the LPIT GPT functionality of the LPit_Gpt IP driver module.
The S32K118 example shows various functions regarding this module, like "Lpit_Gpt_Ip_Init", "Lpit_Gpt_Ip_InitChannel" or "Lpit_Gpt_Ip_StartTimer".
However, when checking the corresponding User Manual or Integration Manual, none of those functions are listed.
Where can I find proper documentation?
RTD Version is 3.0.0 QLP06.
タグ(1)
84件の閲覧回数
Julián_AragónM
Hello @daniel_meier,
The User and Integration manuals are mainly describing the AUTOSAR high-level driver functions (which in consequence, use the lower-level functions). If you require further information about the IP lower-level APIs, you can refer to the LPit_Gpt_Ip.h header.
For example, for Lpit_Gpt_Ip_Init:
* @brief         Function Name : Lpit_Gpt_Ip_Init
* @details       Driver initialization function for LPit instance.
* @param[in]     instance     LPIT hw instance number
* @param[in]     config       Pointer to a selected configuration structure
* @return        void
* @pre           The data structure including the configuration set required for initializing the driver
void Lpit_Gpt_Ip_Init(uint8 instance, const Lpit_Gpt_Ip_InstanceConfigType *config);
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2416134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPIT%20GPT%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELPit_Gpt%20IP%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AELPIT%20GPT%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ES32K118%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8C%20%3CSPAN%3ELpit_Gpt_Ip_Init%3C%2FSPAN%3E%20%E3%80%8D%E3%80%81%E3%80%8C%20%3CSPAN%3ELpit_Gpt_Ip_InitChannel%3C%2FSPAN%3E%20%E3%80%8D%E3%80%81%E3%80%8C%20%3CSPAN%3ELpit_Gpt_Ip_StartTimer%3C%2FSPAN%3E%20%E3%80%8D%E3%81%AA%E3%81%A9%E3%80%81%E3%81%93%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E9%96%A2%E6%95%B0%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%84%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ERTD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF3.0.0%E3%81%A7%E3%81%99%E3%80%82QLP06%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPIT%20GPT%20documentation%20missing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F168838%22%20target%3D%22_blank%22%3E%40daniel_meier%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%A8%E3%82%A4%E3%83%B3%E3%83%86%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E4%B8%BB%E3%81%ABAUTOSAR%E3%81%AE%E9%AB%98%E3%83%AC%E3%83%99%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%A9%9F%E8%83%BD(%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E4%B8%8B%E4%BD%8D%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99)%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82IP%E3%81%AE%E4%B8%8B%E4%BD%8DAPI%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CSTRONG%3ELPit_Gpt_Ip.h%3C%2FSTRONG%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%20%3CSPAN%3E%3CSTRONG%3ELpit_Gpt_Ip_Init%3C%2FSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F**%0A*%20%40brief%20%20%20%20%20%20%20%20%20Function%20Name%20%3A%20Lpit_Gpt_Ip_Init%0A*%20%40details%20%20%20%20%20%20%20Driver%20initialization%20function%20for%20LPit%20instance.%0A*%0A*%0A*%20%40param%5Bin%5D%20%20%20%20%20instance%20%20%20%20%20LPIT%20hw%20instance%20number%0A*%20%40param%5Bin%5D%20%20%20%20%20config%20%20%20%20%20%20%20Pointer%20to%20a%20selected%20configuration%20structure%0A*%20%40return%20%20%20%20%20%20%20%20void%0A*%20%40pre%20%20%20%20%20%20%20%20%20%20%20The%20data%20structure%20including%20the%20configuration%20set%20required%20for%20initializing%20the%20driver%0A*%0A*%2F%0Avoid%20Lpit_Gpt_Ip_Init(uint8%20instance%2C%20const%20Lpit_Gpt_Ip_InstanceConfigType%20*config)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
