LPIT GPT documentation missing
daniel_meier
I'd like to use the LPIT GPT functionality of the LPit_Gpt IP driver module.
The S32K118 example shows various functions regarding this module, like "Lpit_Gpt_Ip_Init", "Lpit_Gpt_Ip_InitChannel" or "Lpit_Gpt_Ip_StartTimer".
However, when checking the corresponding User Manual or Integration Manual, none of those functions are listed.
Where can I find proper documentation?
RTD Version is 3.0.0 QLP06.
Julián_AragónM
Hello @daniel_meier,
The User and Integration manuals are mainly describing the AUTOSAR high-level driver functions (which in consequence, use the lower-level functions). If you require further information about the IP lower-level APIs, you can refer to the LPit_Gpt_Ip.h header.
For example, for Lpit_Gpt_Ip_Init:
* @brief         Function Name : Lpit_Gpt_Ip_Init
* @details       Driver initialization function for LPit instance.
* @param[in]     instance     LPIT hw instance number
* @param[in]     config       Pointer to a selected configuration structure
* @return        void
* @pre           The data structure including the configuration set required for initializing the driver
void Lpit_Gpt_Ip_Init(uint8 instance, const Lpit_Gpt_Ip_InstanceConfigType *config);
Julián
Julián_AragónM
* @return        void
Julián
daniel_meier
Thanks for the information.
I think having a proper and complete documentation independent from the source files is a must.
Either way, looks like I'll be able to generate some doxygen documentation myself from the sources.
%3CLINGO-SUB%20id%3D%22lingo-sub-2416134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPIT%20GPT%20documentation%20missing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'd%20like%20to%20use%20the%20LPIT%20GPT%20functionality%20of%20the%20LPit_Gpt%20IP%20driver%20module.%3CBR%20%2F%3EThe%20S32K118%20example%20shows%20various%20functions%20regarding%20this%20module%2C%20like%20%22%3CSPAN%3ELpit_Gpt_Ip_Init%3C%2FSPAN%3E%22%2C%20%22%3CSPAN%3ELpit_Gpt_Ip_InitChannel%3C%2FSPAN%3E%22%20or%20%22%3CSPAN%3ELpit_Gpt_Ip_StartTimer%3C%2FSPAN%3E%22.%3CBR%20%2F%3EHowever%2C%20when%20checking%20the%20corresponding%20User%20Manual%20or%20Integration%20Manual%2C%20none%20of%20those%20functions%20are%20listed.%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhere%20can%20I%20find%20proper%20documentation%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ERTD%20Version%20is%203.0.0%20QLP06.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPIT%20GPT%20documentation%20missing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F168838%22%20target%3D%22_blank%22%3E%40daniel_meier%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20User%20and%20Integration%20manuals%20are%20mainly%20describing%20the%26nbsp%3BAUTOSAR%20high-level%20driver%20functions%20(which%20in%20consequence%2C%20use%20the%20lower-level%20functions).%20If%20you%20require%20further%20information%20about%20the%20IP%20lower-level%20APIs%2C%20you%20can%20refer%20to%20the%20%3CSTRONG%3ELPit_Gpt_Ip.h%3C%2FSTRONG%3E%20header.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFor%20example%2C%20for%26nbsp%3B%3CSPAN%3E%3CSTRONG%3ELpit_Gpt_Ip_Init%3C%2FSTRONG%3E%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%2F**%0A*%20%40brief%20%20%20%20%20%20%20%20%20Function%20Name%20%3A%20Lpit_Gpt_Ip_Init%0A*%20%40details%20%20%20%20%20%20%20Driver%20initialization%20function%20for%20LPit%20instance.%0A*%0A*%0A*%20%40param%5Bin%5D%20%20%20%20%20instance%20%20%20%20%20LPIT%20hw%20instance%20number%0A*%20%40param%5Bin%5D%20%20%20%20%20config%20%20%20%20%20%20%20Pointer%20to%20a%20selected%20configuration%20structure%0A*%20%40return%20%20%20%20%20%20%20%20void%0A*%20%40pre%20%20%20%20%20%20%20%20%20%20%20The%20data%20structure%20including%20the%20configuration%20set%20required%20for%20initializing%20the%20driver%0A*%0A*%2F%0Avoid%20Lpit_Gpt_Ip_Init(uint8%20instance%2C%20const%20Lpit_Gpt_Ip_InstanceConfigType%20*config)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2417682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPIT%20GPT%20documentation%20missing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20information.%3C%2FP%3E%3CP%3EI%20think%20having%20a%20proper%20and%20complete%20documentation%20independent%20from%20the%20source%20files%20is%20a%20must.%3C%2FP%3E%3CP%3EEither%20way%2C%20looks%20like%20I'll%20be%20able%20to%20generate%20some%20doxygen%20documentation%20myself%20from%20the%20sources.%3C%2FP%3E%3C%2FLINGO-BODY%3E
