LIN Stack CRC
LIN Stack CRC
1,974 次查看
nxp_user001123
Just a quick question. Based on the LIN stack example, we imported another LDF-File (Version 2.1) generated everything., compiled, flashed. Microcontroller is sending, but on our PC-program for simulating the LIN-Slave we had to change the CRC from enhanced (LIN 2.0) to classic CRC (LIN 1.3). So that communication in both directions is working.
We expected : LIN enhanced CRC (because LDF-File is Version 2.1) from NXP microcontroller.
So can we change the used CRC in the NXP S32DS linstack module?
Thanks in advance!
标记 (2)
1,929 次查看
nxp_user001123
Hi Daniel,
Yes sure:
RTD : 5_0
LIN Stack : 2_0_5
We are using the eval board  S32K3X4EVB-T172
1,915 次查看
danielmartynek
Hi @nxp_user001123,
Can you share the LDF?
What frame types do you send?
1,946 次查看
danielmartynek
Hi @nxp_user001123,
Can you please specify the S32K part number, SDK/RTD version and the LIN Stack version?
Thank you,
BR, Daniel
