LIN Interface on S32k118 , Design Studio v3.6.2
yousefdessouki123
I have started recently using the LIN interface on LPUART1 on S32k118q048 EVB. I got the example running and tested it on CANoe. Now I want to make to upload my LDF file to turn the EVB into a LIN master that can communicate with an ECU. I have checked the community posts but I can not find any useful link for those using S32 design studio v3.6.2. I have uploaded my current configuration that works by just sending or reciving data from a slave ECU.  Any help is greatly appreciated.
regards,
danielmartynek
Hi @yousefdessouki123,
Please install this one as well:
danielmartynek
Hello @yousefdessouki123,
In the S32K1xx Reference SW, there is LIN Stack with examples.
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K1-REFSW-D
In the S32DS IDE, you need to install the LIN Stack version that is compatible with the RTD version you use (refer to the LIN Stack release notes).
Let me know, if you need further help,
BR, Daniel
yousefdessouki123
Hello @danielmartynek ,
Thanks for the quick response. I have installed the LIN stack thats comptaible with that of my RTD. However, I can not find the LIN stack on S32 design studio. Where can I find the LIN stack and its files?
danielmartynek
