IPCF problem
IPCF problem
1,088 次查看
chuanlin
Hello,If implementing IPCF Core0->Core1 and Core1->Core0 information exchange, does this configuration item need to add two Unmanaged Channels?
1,045 次查看
DanNguyenDuy
Hello @chuanlin,
No, the channels on each core is independence, but need to be configure symmetrically. (If on core 1 you have (unmanaged, managed, managed) then core 0 also need the same channel with same order (unmanaged, managed, managed), pools number, pool size.)
Incase of using Unmanaged, each core will use it own unmanaged channel to communicate with the other core.
Dan
