How to use the FSLACC(Factory Failure Analysis Access Code) field in FSEC of S32K144 MCU
2,431 次查看
香龙朱
   Hi, all
   I can find only few description of FSLACC in S32K-RM.pdf. I only know we can access the flash memory if the chip is secure and this field is enable. But, I don't know what hardware tools and what software applications I need.
   anyone can tell me?
标记 (3)
2,312 次查看
danielmartynek
These bits enable or disable access to the locked flash memory contents during returned part failure analysis at
NXP factory.
2,313 次查看
danielmartynek
NXP factory.
