How to updata A2L file through ELF file
jinshuaixu
Contributor V
Hello:
       Today ,l meet a quetion,when l want to updata A2L file through ELF file, l find the result is "no map file is available".details are as follows.
1.the compile software is S32DS.
2.the chip is MPC5746.
3.I through S32DS software generates ELF file.
4.the steps l oprates as below:
5.the result is no map file is avaliable:
so,if anyone has the way to solve the problem ,please tell me,thank you.
lukaszadrapa
I can see in the screenshot that it is asking you for map file but you selected elf file. When a project is compiled successfully, you can find *.elf and *.map file in Debug_FLASH folder. Just select the *.map file.
Lukas
