How to do settings to use 2 or more bits in sync break delimiter area?
2,516 次查看
pankajprasad100
I am working on a project in which we use LIN communication.
While I reduce the voltage from 8.4v I am getting a message like  "RcvError(responses invalid header)"
Ref:-Lin stack issue:incorrect sync delimiter length - NXP Community
so my question is how to change the sync break delimiter area to avoid the error?
Thanks & Regards
PANKAJ PRASAD 
2,449 次查看
danielmartynek
Hello @pankajprasad100,
Regarding the delimiter, unfortunately, the driver does not support that.
Anyway, I think this is a HW issue.
Please correct me if I'm wrong, I understand that
  • it works at higher LIN voltage level (> 8.4V)
  • and the error is reported by the CANoe tool.
That's why I was asking about the HW that you use to analyze the signal.
What is the min. LIN voltage specification of the HW tool?
5 回复数
2,493 次查看
danielmartynek
Hi @pankajprasad100,
What MCU, LIN transceiver and LIN diagnostic tool do you use?
BR, Daniel
2,480 次查看
pankajprasad100
Hi Daniel,
We are using MCU-S32K116,LIN transceiver -NCV7329D10R2G, and we are using S32k design studios LIN stack.(we are using LDF file)
Thanks & Regards
Pankaj Prasad
2,473 次查看
danielmartynek
Thank you,
However, I understand that the error "RcvError(responses invalid header)" is reported by a LIN analyzer.
Is that correct?
If so, what analyzer do you use, and is the LIN signal within the specification of the analyzer?
BR, Daniel
2,465 次查看
pankajprasad100
Hi Daniel,
We are using vector CANoe tool to analysis the LIN signals.
Thanks & Regards
Pankaj Prasad
2,450 次查看
danielmartynek
