How to control multiple ISELED strip?
NicoGallo
Does anyone know how to set up the iseled component to control two strip?
I took the iseled example fro s32ds and modified by adding another strip in the component as in the image but I cannot light up both strips.
Do I need to setup two separate DMA and Timing channel?
Thank you for the help
CongDang
Yes, you need to setup two separate DMA and Timing channel if want to use two strips.
