How to configure clock of 32MHz using external crystal for S32K116 controller?
Amrit1
Is there a way to use an external crystal as an clock to the a S32K116 controller to generate a clock frequency 32MHz? If yes, could you please provide some pointers on how to, and also what configs needs to be set?
Also can PLL be used for S32K116? From what I could see PLL is not added as part of S32K116 controller, from what I could see it is not.
Senlent
Hi@Amrit1
the picture i show you in the last reply is from S32 DS V3.4 /V3.5
you can find excel file in the link below.
https://www.nxp.com/search?keyword=AN5408&start=0
Senlent
Hi@Amrit1
yes,no PLL used on this chip,
you can change the external crystal to 32MHz, but few customers use this way
Amrit1
Is there a way I can get the sequence or the configurations I need to use it in this method? (Or any excel sheet which will generate the code for a set config)
Senlent
Hi@Amrit1
