How to configure Csec module return M4 and M5 values based on all zero UID after load csec key?
BigJulie
When i loaded M1,M2 and M3 generated by Csec key based on all zero UID in S32K, The Csec module return values of M4 and M5  based on the UID of non-zero.
so How can i configure Csec module return the values of M4 and M5 based on all zero UID ?
Baset regard,
BigJulie.
Tags (2)
lukaszadrapa
there's no such option. SHE specification says that UID should be used for M4/M5 calculation (it does not talk about wildcard in case of this functionality).
Lukas
