How to remove Csec key wildcard protected attribute?
1,284 次查看
BigJulie
i know how to load a csec key in S32K,but how can i change csec key attribute of wildcard ?
Best regard,
BigJule.
标记 (2)
1 回复
1,276 次查看
lukaszadrapa
you need to update the key as described in this application note:
https://www.nxp.com/webapp/Download?colCode=AN5401&location=null
https://www.nxp.com/webapp/Download?colCode=AN5401SW&location=null
... change attribute wildcard back to 0, increment counter value and change key, if needed. Changing of wildcard back to 0 is not forbidden.
Lukas
