How to build code by command-line about S32K312?
f-nelson
Hi NXP:
now we've developing firmware by S32DS3.5 IDE and it can work as well.
recently we got a requirement for building code by command-line, and
I read relative document from S32DS help content, but it will occur
error about JAVA. for more detail, please take a look 20250212-metadata.log.
please help us, thanks.
20250212-cmd_test_result.txt
IsaulO
Hi @f-nelson ,
It seems some files are missing for a successful compilation, similar issue was discussed in the community, please refer to the following link: How to use command line build the S32K(312) Design Studio 4.4 code? - NXP Community
Where it is mentioned that as a workaround, you need to add the paths for these files manually (by the -I option).
Please let me know if the solution was useful for you.
BR,
IsaulO.
