How synchronize Emios channels with FlexPwm channels
1,197 次查看
Silvano
I am trying to synchronize Emios channels with FlexPwm channels but I don't know how to do it.
Someone can help please ?
I attached my project here and a picture of the oscilloscope (in green/yellow/ pink : flexpwm in blue : emios signal). We can see that the signal blue is not synchronised with the flexpwm channels.
I guess it is because I use the counter external bus for the emios but by using the counter internal bus, I can not create a phase shift from the settings.
Thank you,
1,189 次查看
danielmartynek
Hello @Silvano,
Please be advised that customers who have been granted early access to such products have assigned their field engineers. Your designated field engineer should serve as your primary support channel for any issues, concerns or queries you may have about this product.
Our online support team will be opening a wider range of support for this product once it has been officially released. Until then, they will not be equipped to provide the desired assistance.
We appreciate your understanding in this matter and look forward to further enhance our partnership with you. Should you have any questions, please feel free to connect with your field engineer.
