MCSPTE1AK144 Development Kit Application Software ver.1.2 Build Project Error
已解决
跳至解决方案
3,489 次查看
Juraj_PANCIK
Dears,
I tried to build project "MCSPTE1AK144_BLDC_6Step" in order to get  file for flashing of MCU (MCSPTE1AK144_BLDC_6Step.srec) in version MCSPTE1AK144 Development Kit Application Software 1.2.
In difference from version 1.1 I got in this build in ver.1.2 the error message (pls see attached file Error Message.jpg). The S32DS extension and updates is on attached picture 240311 S32 Desig StudioCapture.jpg. See also note bellow [1].
Before work I set parameetrs for LINIX motor by running SetMotor-LINIX_45ZWN24-40.bat.
As I wrote - the build in version 1.1 is without problem.
Thank you very much for your kindly help
Juraj, teacher & development eng in Schaeffler AG.
[1]
- S32 Design Studio (S32DS) for ARM 2.2
- S32 Software Development Kit (SDK) for S32K1xx 3.0.3
- S32K14x_AMMCLIB_v1.1.35
- FreeMASTER 3.1.4.5
1 解答
3,460 次查看
petervlna
It looks you are missing gdflib.h
This is part of AMMCLIB. Set your library paths accordingly your files location in project settings.
Includes and also libraries paths.
Peter
在原帖中查看解决方案
2 回复数
3,461 次查看
petervlna
Peter
3,423 次查看
Juraj_PANCIK
Hi Peter,
thank you very much for your reply. I'll try do it.
I want remark that project mentioned by my is  a part of delivery of SW for EvaKit from NXP ver.1.2.  and in  such way it should not contains such errors ( as a sample it should be "buildable " without additional effort). The ver 1.1 of SW for this EvaKIt  is OK - this ver.1.2 need additional efort as you wrote.
Thank again. Have a nice day. Juraj
