Hard fault occur, other interrupt handler can running or not?
1,183 次查看
chunling
If S32K146 have a hard fault, and there is no hard fault handler registerd, then other interrupt handler can running or not?
1,176 次查看
Senlent
Hi@chunling
hadrfault exception is permanently enabled, and has a fixed interrupt priority of -1,just lower than reset and NMI interrupts. so except for the reset and NMI,other interrupts can not run.
br!
     Jim,
1,177 次查看
Senlent
Hi@chunling
br!
     Jim,
